LV2015: how to change hotkey for CTRL+ALT-resizing,
I installed LabVIEW 2015 today as I really liked some of the new featers.
The new resizing option (ctrl+alt+mousedrag) to reduce unused space in the BD is a sweet thing but I can't get it to work as the combination Alt+Drag is already bound to move windows around. I use this frequently and wont change that shortcut.
No sweat - I'll just change the key binding in LabVIEW to something different (Ctrl+Shift+Drag would make sense).
Or so I thought.
Is there some way to adjust that key binding? It's not accessible through the normal options dialog AFAIK.
(3,661 Views)
Hey,
I found no information, that this function can be edited.
The named other combination is already used for the function to Duplicate a selected object and moves it in one axis:
Keyboard Shortcuts - LabVIEW 2014 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/keyboard_shortcuts/
Adding or Reducing Space on the Front Panel or Block Diagram - LabVIEW 2015 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/371361M-01/lvhowto/adding_working_space/
Best Regards,
Jonathan
AE
(3,611 Views)
Ctrl+Shift+Drag is only duplicate+on-axis movement when done on an object, when done on the background it's bound to panning the diagram around. And I'd be fine with not having that.
But I'm afraud it's another hard-coded feature 😞
(3,603 Views)
