08-09-2010 05:29 AM
I have migrated a LabVIEW project from LabVIEW 2009 SP1 to LabVIEW 2010. Everything works fine - execution in development system - except the compilation of the build specification. I have tried it several times with different options --> new project from scratch, new build specification with no success. Everytime error 74. I have attached a screenshot and two logfiles.
08-09-2010 06:15 AM
Can you attach your vi?
08-09-2010 01:12 PM
it is very difficult because there are very much dependencies in my project - the build was ok in LV2009 SP1.
08-10-2010 06:37 AM
Hi Joachim,
have you mass compiled your project?
What does Mass Compile do in LabVIEW?
http://digital.ni.com/public.nsf/allkb/654877E62A97B72986256C95006F9B24?OpenDocument
How do I Mass Compile VIs, LLBs, or Folders in LabVIEW?
http://digital.ni.com/public.nsf/allkb/AA97C01071D7CF678625695100582F40?OpenDocument
Mary
NIG
08-11-2010 04:01 AM
I've made a mass compile of the whole project (no warnings) and also of the user.lib and vi.lib/addons folder. I've attached the logfile of the build specifiation.
Kind Regards,
Joachim
08-11-2010 06:13 AM
Hi Joachim,
have you tried to compile a new build specification created in LV 2010?
Maria
NIG
08-11-2010 01:32 PM
Yes I've made a new build specification in LV2010 - also the same. Before I've mass compiled the whole project and the whole LabVIEW2010 folder. What does the message "LabVIEW: Memory or data structure corrupt. Method Name: Linker:Write Info To File " mean? STRG-SHIFT Run has no effect.
Joachim
08-12-2010 02:58 AM
Hi Joachim,
can you upload your code to the FTP server from NI, so that I can test your code by myself?
Upload:
"Please put your project files into a zip file and include your name (joachim082.zip ). Then upload the file to ftp://ftp.ni.com/incoming using a web browser or FTP program.
If you are using any National Instruments hardware, it will also be helpful if you export your MAX configuration and include that it in the zip file so that I can simulate your exact setup. To do this, open Measurement & Automation Explorer and go to File » Export.. and follow the instructions of the wizard. Be sure to "check all" when prompted for what configurations you want to export.
Once the upload is complete, please reply to this post and let me know it is there."
Mary
NIG
08-30-2010 04:10 AM
have quite the same problem building the project. Under Labview 8.5.1 everything worked fine, then moved to LV 2010, getting the same error all the time, even under LV 8.5.1 building does not work anymore. Any other suggestions than mass compile?
08-30-2010 04:13 AM
I've contacted NI - apparently it is a bug.
