09-09-2011 12:21 AM
When I use the LV run time to access the 'can frame output.vi' from a .llb I get an error that it can not find the CAN interface. Is this because it can't access the
09-09-2011 02:15 AM
Are you sure you are passing the right name of the CAN interface name from the TStand variable?
Can we see the code of the VI you are calling by TStand?
09-09-2011 03:54 AM
JoVMo,
Please include VIs wherever possible along with screenshots. It makes it faster for us to see the problem ure facing.
09-09-2011 05:46 AM
I made the current value default in the vi and used the default value in TST for the interface. This worked.
With the DE set as adapter it didn't gave errors. Whit the RT set as adapter the error showed.Maybe the RT didn't took the interface value with him from TST.
