When I use the LV run time to access the 'can frame output.vi' from a .llb I get an error that it can not find the CAN interface. Is this because it can't access the
I made the current value default in the vi and used the default value in TST for the interface. This worked.
With the DE set as adapter it didn't gave errors. Whit the RT set as adapter the error showed.Maybe the RT didn't took the interface value with him from TST.
