LV report:scalable FP
I want to append a front panel to HTML report.
But the front panel is too large.I would like resize the front panel in the HTML report with LV so that it can fit one screen. Is there a way out? Thanks.
(2,242 Views)
Hello, Zhichao.
I'll do my best to answer your question.
You could try setting the VI option to print panel when VI completes execution. Along with that, use a pdf printer driver to print the panel image to a file that you should be able to append to your HTML report.
Hope this helps.
Mark Ridgley
(2,242 Views)
