05-13-2008 09:35 AM
Solved! Go to Solution.
05-14-2008 10:52 AM
Hi Stinky,
Does your DAQ card not work in VB 6? Also are you moving the National Instruments folder under the All Users program folder or just your accounts? When the datasocket installer runs do you have any options for start menu shortcut locations?
05-14-2008 12:58 PM
05-14-2008 04:52 PM
01-23-2009 11:34 AM - edited 01-23-2009 11:40 AM
Hi Sappster,
Did you find any solution for the problem, beside not moving the shortcut? I have exactly the same behaviour after installing LV RTE 7.1.1
Regards.
01-23-2009 01:29 PM
Easy fix, and I do this with a lot of other shortcuts for other programs... Just make them hidden files.
If you delete them and it does some kind of update; it will detect that they are not present and add them back in.
