LV_ArrayToImage_v2 - MOVIMED AF 1501C
HI,
I'm developing an application using LabVIEW 2010, NI cRIO-9073 and AF 1501C module. I followed every step to configure this module but I can't run some examples because gives me an error: "Failed to load shared library nivision: LV_ArrayToImage_v2:C".
Software Installed:
- NI Vision RT 10.0.0.3.0
- LabVIEW RT 10.0
- NI-RIO 3.5.0
- NI-VISA 5.0
Any suggestion?
Thanks in advance for your suggestions,
Ing. Jorge Valerio Araoz
Ingeniero de Ventas
SOCIEDAD INDUCONTROL INGENIERÍA S.A.C.
http://www.inducontrol.com.pe/
jvalerio@inducontrol.com.pe
Celular/RPC: +51-986666633
RPM: *271058
Teléfono: +511-4405225
Calle Manuel Fuentes 976B - Lima 27 - Perú
"No es lo que hacemos, es lo que hacemos posible." - National Instruments
(2,506 Views)
Hi
  Sorry, your controller does not have enough memory to version of LabVIEW 2010 and later. I recommend you use the version of LabVIEW 2009
Diogo Aparecido
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(2,486 Views)
