06-19-2014 12:28 PM
@crossrulz wrote:
This code runs on an FPGA. That is why this doesn't work. There are no events in an FPGA. And I'm pretty sure you can't even get a reference to a control in FPGA either.
I can't really think of a time when having a property node, or invoke node on an FPGA would be a good idea.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-02-2014 09:16 AM
So, now I've had more time at the test bench and tried passing a boolean between the VIs using a global variable.
This works just fine with two "normal" VIs, but as soon as I try it with any VI that is part of the "fpga target" it stops working.
- I get no error messages
- It has no effect, the global boolean reference inside any VI that is part of the fpga target never changes value regardless of what the global value is set to from the outside.
Perhaps I'm doing something wrong?
Should it work to pass data into fpga code through global variables ?
Ji Ro
07-02-2014 09:32 AM
I haven't tried using a global variable in FPGA. I've used local variables without any issue.
I'm not sure if they were around in 8.6, but you could look into using a Register. Or use block memory.
