Since support now wants all these questions posted in the forums I will try it here...
How come LV 8.5.1 has trouble drawing a simple text box? LabVIEW has crashed a number of times. This is on a cleanly installed system. This program is designed to run continuously and reliably and did so under LV 8.2.1. Now with an update to 8.5.1 I am losing this reliability.
Here is the traceback from a memory protection fault.
Thread 0 Crashed:
0 libSystem.B.dylib 0x90004910 szone_malloc + 4056
... bunch of apple libraries.
13 com.apple.QD 0x91788ed0 StdText + 308
14 com.ni.labview 0x005931dc LVHostDrawable_DrawTextBox(Rect*, long, unsigned char*, long, FontType_t*, DColorSet) + 1540
As you can see LV is trying to draw a text box. Simple no? This is a large program that has a lot of asynchronous loops, DAQ, GPIB, Serial, DIO, and data logging.
The only other hint I got was from the lvlog files. I have the DialogWarn token set so they give more warnings than usual.
plotsupp.cpp(4051) : DWarn: too many points in plot
$Id: //labview/branches/Jupiter/dev/source/panel/plotsupp.cpp#53 $
0x006FF498 - <unknown> + 6FF3C8
Huh! How many points is too many? Almost all my plots are history charts with maybe 1000 pts max. Probably more like 200.
-Scott
LV 8.5.1
Mac OS X 10.4.11
PPC
