LV 8.2.1 Error 66 or 1379 occured at open Application Reference. A LV 8.2.1
Hi Ben,
thanks, now I will track the issue-list, too. 🙂
Salvator
Message 11 of 16
(1,296 Views)
We had the same problem!  The solution was to install NI Device Drivers (3 CDs) on the server computer.  It solved the problem.  We were using LabVIEW 8.5.  The device drivers may contain some NI security libraryfiles.
Message 12 of 16
(1,260 Views)
Specifically you need to install Logos.msi from \Products\NI-Logos directory on the drivers CD. It is the NI login /network security for Networks that includes VI Server, even if no security is used.
Message 13 of 16
(1,246 Views)
Super !
CAR 49G8P500 is now fixed with LabVIEW 8.5.1
Smiley Very Happy
Salvator
Message 14 of 16
(1,143 Views)
I have been using LV 8.2.1 and I ran into this problem so I decided to try 8.5.1 but it still does not seem to be working for me.
I built an application in 8.5.1 that does nothing but run an event structure, it has server.tcp.enabled=True and access set properly.  I then installed 8.5.1 runtime on another machine (this machine also has 8.2.1 runtime and 8.2.1 installed on it)
When I try to connect to this application, from my 8.5.1 machine, I get error 66.
What am I doing wrong??
bryan
Message 15 of 16
(1,055 Views)
Bryan,
Look at my earlier reply for this isse and LOGOS.MSI instaltion that fixes it.
Konrad
Message 16 of 16
(1,022 Views)
