09-29-2006 10:01 AM
09-29-2006 04:25 PM
09-29-2006 07:10 PM
10-02-2006 08:00 AM
10-02-2006 02:45 PM
Here is a link to a similar thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=200310
Common thing appears to be a TAB control.
as mentioned in the above thread a copy & paste into a new vi is a work around.
10-02-2006 05:20 PM
06-02-2007 01:15 PM
We are getting the same problem. NI needs to fix this ASAP as it is killing our new Labview software development. It has rendered our new code useless, splitting the front panal and no scroll bars!!!. About 6 months of work will have to be redone in Labview 7.x to work around this problem. This should be a priority fix for NI, it exists in Windows Professional and vista.
06-02-2007 10:19 PM
06-03-2007 11:13 AM
Mike, See my other '1/2' post. It is a major issue if it translates to your final builds. We tried your suggestions and they didn't work in our case. The copy paste solution works if you have a small top level VI. Our top level VI's have a lot of code which is why we're also having no luck doing a copy/paste to a new vi. And on another note, I don't post much here as we generally don't have problems with Labview. This is the first instance we're dealt with where we can't code our way out of the problem. So my "line of work" works when the tools work. And our coding works as over 20 companies use our software. Take a look at our client base. http://www.ccm.udel.edu/Tech/CDSindex.html You may recognize some of the names.
I've seen the earlier posts and NI hasn't fixed the problem with 8.2.1. I'll use whatever melodrama that's needed on these threads to match our current dilemma
John
06-04-2007 11:09 AM - edited 06-04-2007 11:09 AM
John,
I'm no longer in our support department, but I've been watching this thread since I originally responded last year. Despite the importance of this issue, one of the big obstacles towards fixing it is that we still haven't been able to reproduce it at NI. As Jeff mentioned, without that it's nearly impossible to diagnose (and correspondingly fix) the issue. (You may notice that we NI folks keep requesting an example VI, but the specifics of the situation have prevented it thus far.) If you can send us a small VI that demonstrates the behavior, we'll be glad to send it on to R&D for investigation. I can certainly sympathize with your frustration, and I wish I could give you a better answer than this.
Thanks.
Message Edited by sarahk on 06-04-2007 11:10 AM
