キャンセル
次の結果を表示
次の代わりに検索
もしかして:
[LV 2021, myRIO toolkit] Problems with LV resolution/scaling, font size
解決済み
解決策を見る
Hi, I have a problem with the way Project Explorer and some settings are scaled on my computer (Microsoft Surface Pro 6) in LabVIEW 2021:
I have tried changing the screen resolution, font size and high DPI settings but nothing solved the problem. Is there any way to change the font size in LabVIEW?
Or is it possible to use myRIO toolkit in LabVIEW 2023? I don't have such problems in newer version, but then I cannot use myRIO toolkit...
0 件の賞賛
メッセージ1/3
1,173件の閲覧回数
解決策
トピック作成者kdoqw02が受理
Try the settings in NI MAX Font Size Too Small or Large. It is applicable to LabVIEW as well.
Are you using Windows 11? The myRIO Toolkit is not supported in Win11. NI Product Compatibility for Microsoft Windows 11
https://tmesystems.net/
メッセージ2/3
1,151件の閲覧回数
Thank you! Changing Scaling performed by: System in high DPI settings helped.
0 件の賞賛
メッセージ3/3
1,143件の閲覧回数
