[LV 2021, myRIO toolkit] Problems with LV resolution/scaling, font size
Hi, I have a problem with the way Project Explorer and some settings are scaled on my computer (Microsoft Surface Pro 6) in LabVIEW 2021:
I have tried changing the screen resolution, font size and high DPI settings but nothing solved the problem. Is there any way to change the font size in LabVIEW?
Or is it possible to use myRIO toolkit in LabVIEW 2023? I don't have such problems in newer version, but then I cannot use myRIO toolkit...
(1,175 Views)
Accepted by topic author kdoqw02
Try the settings in NI MAX Font Size Too Small or Large. It is applicable to LabVIEW as well.
Are you using Windows 11? The myRIO Toolkit is not supported in Win11. NI Product Compatibility for Microsoft Windows 11
https://tmesystems.net/
(1,153 Views)
Thank you! Changing Scaling performed by: System in high DPI settings helped.
(1,145 Views)
