01-12-2021 11:01 AM
Just "upgraded" my main machine to Win 10 (was Win 7) at demand of a customer, for "security" reasons.
Have to turn firewall and other security options OFF (yes, I see the irony).
LabVIEW 2018 SP1 (32) is practically unusable now. My program takes 15 seconds from mouse click to menu pop up. Right click on a VI call and it's 10 sec before the menu pops up for breakpoints, etc.
Switching between windows is fast. Menus in the project explorer work normally. If I QUIT my app, it's 30 seconds before things go away (used to be 2 sec). I can close the project and it does NOT warn me about aborting VIs, even though those VIs are still on screen, showing as running. LV using about 16% total CPU, but that shows as "very high". I'm on i7-3770 at 3.4 GHz, not a slouch machine. Mem usage is 500 MB, out of 16 GB in the machine. I did the 3072-extension trick, in case that comes into play.
Any ideas?
Blog for (mostly LabVIEW) programmers: Tips And Tricks
01-12-2021 11:13 AM
Clean Object Compiled Cache & Mass Compile Then restart LabVIEW
mcduff
01-13-2021 05:20 AM
Then you're unlucky. I've only had extremely smooth and invisible transitions when upgrading to Win 10. The biggest trouble was forcing and old driver to be used for a USB-dongle since it only had a Win 7 driver.
01-13-2021 09:44 AM
Hi Steve,
For what it's worth, I'm running LV2018 on an "upgraded" Win10 laptop with much less power than your machine. But in my case, I did the upgrade before I installed LabVIEW.
01-13-2021 01:16 PM
Did that. Deleted cache, trashed all PPLs and rebuilt everything. No change. Still running in sludge.
01-14-2021 08:40 AM
01-14-2021 02:55 PM
Do you have the f1 patch for 2018 SP1? One of my customers had run into issues running one of their main applications after upgrading from Windows 7 to 10 which was due to some additional overhead drawing many large front panels in Windows 10.
01-15-2021 04:10 PM
My version reports as 18.0.1f4. I assume the "f4" is later than the "f1" you refer to.
01-15-2021 04:24 PM
Correct
