10-13-2017 10:23 AM - edited 10-13-2017 10:29 AM
Please try to reproduce the following problem I just discovered. I did not check with other combinations, other control types and property types. First testing only this.
I think this is a bug...
EDIT: ok, maybe it is not a bug, but this is the way how it works. I realized, there is an option to change to write mode that individual entry. But still, after right click, it would be handy to change the entire propnode to Write mode using the first entry from the right click menu...
10-16-2017 05:22 AM - edited 10-16-2017 05:27 AM
Hi Blokk,
I could reproduce this behaviour and I don't think it is a bug.
After you have created the element "Edit Position", you can right-click on it and select "Change All To Read". Then right-click again and select "Change All To Write".
(the top property node element determines if "Change All To Read" or "Change All To Write" is displayed first, but you can get to the other one by choosing the "opposite" first and then right click again)
Eric
10-16-2017 07:10 AM
@EricHayoz wrote:
Hi Blokk,
Eric
Ok, but even if this is not a bug, it is not too comfortable. I should get the "Write mode" for all entries in one step.
