01-06-2017 12:15 PM
Hi All,
I installed LV 2016 several month ago and have worked in it just fine. Today I opened it and I no longer have any icon available in my functions or controls palette, nor does a search return any avilable functions or controls. The files are located in the proper location on disk though.
Any suggestions how to fix this?
Solved! Go to Solution.
01-06-2017 12:21 PM
Is this evaluation software? I'm not sure what happens when it expires, but this sounds like something that should happen.
01-06-2017 12:23 PM
By any chance, did you install using a limited (like a Student) License, or an Evaluation version? Sounds like LabVIEW has "timed out" on you ("several months ago" sounds like 3 months = 90 days ...).
01-06-2017 12:32 PM
Although I didnt think to check that, I have an active license and it is activated.
01-06-2017 03:19 PM - edited 01-06-2017 03:27 PM
Evaluation (or expired licenses) don't remove features like this, it just won't launch. When you run LabVIEW a dialog comes up and says your license expires in X days, with a check box to say don't bother me about this on startup anymore. Then when those days expire the Launch LabVIEW button is disabled...but now that I think about it I wonder if you could just enable that button and see it work.
Anyway this means you can't open LabVIEW or VIs after it has expired but I assume if LabVIEW is left open you don't get a nag screen, just no rebooting or quitting.
Edit: Just tested, enabling the Launch Button when it is disabled using system level calls does work, but clicking it does nothing. I should have known NI wasn't better at protecting itself than having that work.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-06-2017 03:55 PM - edited 01-06-2017 04:01 PM
Hmm, i get what youre saying, but that isnt the problem either. This is a standard license and i get no luanch button on bootup. Ive evaluated software before so i know what it looks like. Im even unable to add items to my palette. Im thinking of doing a complete reinstall, which is a pain
edit: im going to try a repair of labview first. Ive never tried this before so ill find out if it gives good results.
01-06-2017 04:52 PM
I used the NI software repair and that fixed the problem. Still dont know what caused it, but its fixed
01-06-2017 04:56 PM
Don't forget to mark YOUR answer as the solution!
