LV 2012 type def issues
@Vadim wrote:
Because type definitions identify only the data type, only the values that are part of the data type update.... Because the item names in ring [combo box] controls do not define the data type, changes to ring [combo box] control item names in a type definition do not change the item names in instances of the type definition."
Yes, only the type itself.  Default values are not part of the data type.  Try the strict typed definition and see if it retains your default values.
Message 11 of 14
(457 Views)
i will thank you, but the thing is, it does retain them now, after i did what's described earlier, for many times.
Message 12 of 14
(453 Views)
Be careful if you don't know exactly what you did.  There is a fair probability that it "accidentally" worked and it will rear its ugly head again down the road when you change that unknown condition.
Bill
CLD
(Mid-Level minion.)
Message 13 of 14
(446 Views)
so, based on what you telling me, I should go with the .ini file? that's the plan, but I have a huge chunk fo the code inherited in the lv6.1, so I wrote the new model in 2012 adaptable to the front interface of lv6.1 with hope that one day I will convert and then do the proper .ini file.
Message 14 of 14
(440 Views)
