LTpowerPlay LTC2974
I am new to Labview and any suggestions will be appreciated. Here's the problem,
I am trying to connect Labview with LTpowerPlay so I can get the voltage/current readings from different rails of two LTC2974 chips directly from Labview.
I was able to open LTpowerPlay using the 'Calling System Exec' VI and I am ok with selecting chip and loading project file manually, but it would be great
if I can also automate these. But I cannot figure out how to run the script file (read 2974 registers) to get the current/voltage readings through Labview.
Has anyone done that before? Any suggestions?
Thanks a lot.
Chenyang
(3,091 Views)
Here is a good white paper about scripting languages in LabVIEW.
https://www.ni.com/en/shop/labview/scripting-languages-and-ni-labview.html
If you have further questions, can you clarify some more information about what you have tried?
(3,055 Views)
