LINX firmware wizard
Hello everyone .
I have a question about linx . I have a program in labview and i can run it on my arduino but the problem is that whenever i want to run the code I need to use the firmware wizard in LINX . is there a way to run codes on arduino from labview without having to go to the firmware wizard each time ?
(1,001 Views)
As I understand you are looking a way to find programmatic way to upload the code in to Ardino.
I find only page at the bottom, unfortunately my browser blocked me ti check what there is written however I read that there should be a console command.
https://www.feeds.labviewmakerhub.com/forums/viewtopic.php?t=707&p=4284
__________________________________________
The best way to thank, is to give KUDOS
(894 Views)
