LINX RaspberryPi PS4 controller problems
Hello everybody👋
I have a problem, maybe someone can help me.
I have a little 4WD Car, controlled with a raspberrypi 3 and an Arduino MEGA. Now i will control the car with an PS4 Controller.
I installed the Makerhub PS4 Lib. The controller works with the examples.
Ah the RaspberryPi is in my home wlan and the controller is connect to the pc.
When i will load the code to the Raspberry then i get the error below. It's in german.
I hope someone can help me.
(234 Views)
Hello
I can see you have done some interesting project.
So can you translate the error message for us?
(175 Views)
Of course i will try.
It means: Query input device.vi was loaded to the target system with errors and closed
(169 Views)
Hello and sorry for getting back to you so late
So which version of LabVIEW are you using right now and have you performed some updates of your software?
(126 Views)
Hello and no problem
I use LabVIEW 2020. I made no updates.
(104 Views)
