05-27-2013 08:48 AM
I'm trying to make a LED blinks in any other color but yellow which is the default color, i did change this color to green in the VI properties, however when building my .exe i have noticed that the LED still blinking yellow, so i tried to change this color by using property nodes by i didn't figure out how to do it, i even don't know if it can be done by programming, does anyone know how to fix this ?
Thank you,
MGarry
Solved! Go to Solution.
05-27-2013 08:59 AM
what hardware are u using? did you try a smal test to see if it works without the rest of the program?
can you share the VI you are using so we can see what is going wrong?
05-27-2013 10:26 AM
Thanks for your reply, i'm not using any hardware, even if i am i think this has nothing to do with hardware it's only a matter of programming, the VI is created with LV2011, i joint a small program to illustrate the issue in both versions 8.6 and 2011, the LED is blinking RED in the VI ,though once the .exe is built (LV 2011) i can run it and see the LED blinking Yellow.
Thank you,
MGarry
05-27-2013 10:37 AM
The blink color and rate are global properties - you can open the LabVIEW.ini file and search for the relvant line, then copy it into the application's INI file and restart it. That should set the color.
05-27-2013 11:08 AM
The line "blinkFG=XXXXXXXX" in the LabVIEW.ini file you're right tst, thanks a lot.
