LABVIEW INSTALLER FAILS UNDER CERTAIN ADDITIONAL INSTALLER SELECTIONS
Under Additional Installers of the Installer Properties menu for LabVIEW 2013 SP1 f2:
  1. Application installs normally when NI-DAQmx Core Runtime 9.8 is selected.
    1. Will not populate MAX with configuration.nce file.
  2. Application will not install when NI-DAQmx Application Development Support Software is selected; looks for license and never stops – keeps looping.
  3. Application will not install when NI-DAQmxMAX Configuration Support 9.8 is selected; displays message: “Currently executing National Instruments help install into Visual Studio 2010.
I need the installer to do a silent install of the MAX nce configuration file during the installation.
(3,642 Views)
Hi sfrosty,
This seems to be like an error with the driver, have you try to repair or reinstall DAQmx driver and then create the installer?
Carolina
(3,584 Views)
Re-installed driver 8.6. Rebuilt - same results. Tried install on yet another machine - same result.
(3,552 Views)
Accepted by topic author sfrosty
Deleted all Nationional Instrument components.
Re-installed LabVIEW 2013 from disks. Re-installed DAQmx 9.8 from NI website.
Re-built installer. Everything now working normally!
(3,532 Views)
Oh, also re-installed MAX 2014. Smiley Happy
(3,516 Views)
Hi sfrosty,
I am glad to see you got it working after the reinstall.
Carolina
(3,506 Views)
