01-14-2013 05:02 PM
This vi will convert the modbus commands to a string. You can have this in your code, but I chose to use it only to create the string that I send.
01-14-2013 05:09 PM
Any chance of getting that convert to string vi in Labview 2010 compatibility?
01-14-2013 05:28 PM
Wow, no thanks or Kudos but a request to convert? Sure I would be glad to for a fellow member.
01-14-2013 05:31 PM
Sorry, MANY THANKS AND KUDOS!!! too focused on programming to be a decent human being I guess, my apologies!
01-14-2013 08:58 PM
I was just joking with you about the thanks and/or kudos.
I often can't help people very much since there are so many people on this forum smarter than me. Since I get so much good info, I like to help when I can.
If you run into any more questions, don't hesitate to ask. I was able to make my AKD drive work and it has been running fine in the customer plant.
01-15-2013 06:31 AM
The screen shot I made before of the write command is wrong, it is really a read. Here is writing the command to home the servo.
04-18-2013 01:01 PM
nonecure, would you post a copy of your code? I may have to utilize this LAC as well, and this would help out so much!
Thanks!
04-18-2013 01:30 PM
Attached is my code for the Kollmorgen servo. The servo engine vi runs in the background, and the servo request vi allows your app to send and receive commands to and from the engine. The test manager vi is what I use to test this out standalone. I am using the dynamic mapping feature of the drive, so I am reading/writing the 8192 area of the drive. The dynamic map file shows the mapping I used.
-Doug
04-18-2013 01:34 PM
Sweet! Thanks. Kudos!
04-22-2013 07:13 AM
Hi Doug,
Do you have a copy of 'PostAlarm.vi' and 'G_System.vi' that you can post up to accompany your code. These weren't included in the zip file.
Kind Regards,
Oli
