I think if worst comes to worst, LabVIEW allow you to specify by hand
the label on each knob (or other front panel control tick. I think
one may do this by double clicking on the label next to eack mark. I
one started with a decimal labelling this would require six edits. If
what is desired is, say, two digit hexadecimal labelling (00, 01 ...
FE, FF) this method would be a pain.
On Jul 9, 1:10 pm, Kaspar <x...@no.email> wrote:
>Hello,
>I have a knob control that has a unsigned byte for the data representation, the scale and data range are both set to 16 (base 10) to 31 base (10). I would like the scane and the digital display to be a 2 char hex value. I can get the digital display to display as hex, but I cannot get the scale to be in hex, it only wants to be in floating point or base 10 numbers.
>I want the scale display to be in hex, so I would see the value 10 to 1F on the scale, which are the numbers around the know. Anu ideas what is going on?
>Regards, Kaspar
