I wrote a LabVIEW program that communicates with: two NI 9482 relays connected to my Dell laptop via an NI cDAQ-9174 chassis, as well as a Keysight 34461A DMM. I'm using LabVIEW 2018 (32 bit) with NI-VISA 18.5 and NI-DAQmx 18.6 installed. For the Keysight instrument I installed plug and play drivers by drag and dropping the files into the '.libr' folder. The program works seamlessly without issues.
I then bundled my '.vi' into an '.exe' file and moved it to a Dell 7212 Latitude tablet. This machine is running the same version of Windows (Windows 10). LabVIEW runtime engine 2018 (32 bit) was installed, along with the full versions of DAQmx 18.6 and NI-VISA 18.5. Upon launching the ',exe' I am able to run the vi and control the relays but NOT the DMM. NI-MAX also recognizes the relays but not the DMM. I can see the DMM through Windows device manager, but I receive the error shown in the attached PNG file. I have called both Keysight and National Instruments support but am still unable to figure out what the problem is. Any help would be greatly appreciated!
