08-10-2011 10:09 AM
This is true. I do have a rs232 driver I've made and I was hoping to convert it over to USB. But the device doesn't have a USB model code or manufacturer ID so you can't use this method, http://zone.ni.com/devzone/cda/tut/p/id/4478, to convert the rs232 driver. I do need the USB speed for doing fast material scanning. We like the Keyence performance but it’s basically useless to us. We are looking into other products.
THanks for the info.
08-10-2011 10:12 AM - edited 08-10-2011 10:16 AM
Could you scan it with the Keyence software and save it to a file. Then use labview to read the data file after the fact?
How does the LK-G show up in device manager when plugged into a usb port?? Does it show up as a comm port?
08-10-2011 10:28 AM
If you absolutely have to get to the usb packets and reverse engineer the protocol, it can be done with some external hardware.
08-10-2011 10:36 AM
Yeah that is probably a limitation for your app, it's a shame as it's a pretty good device other than the high-speed comms. I'll throw a couple of options out there you may have already considered:
1 - use the 'data storage' commands from serial - there are four commands to initialize/start/stop/and then transmit high speed data. Won't work for you if you have to stream live data continuously, but it will let you do bursts of high-speed acquisition to cover a specific event.
2 - use the analog outputs from the Keyence device, bring them in through an NI DAQ unit. That could be as simple as a USB DAQ module - I think the USB-6009 gives up to 10ks/sec. We end up using a lot of analog inputs/outputs in my lab to transfer signals and data - even in the 201n's (non digital? really? :-D) this is still frrequently the simplest solution.
08-10-2011 10:55 AM
The issue is I have to sync other measurements. Storing the thickness data to a file then syncing post proccess isn't really a good option. I have to show the information in real time.
08-11-2011 08:00 AM - edited 08-11-2011 08:01 AM
Your best bet is to synch the analog output to whatever device is measuring your length. Even over USB, most system architectures have a hard time receiving the amount of data that a Keyence system provides simply because of the processing rate at both ends. The analog will give you a much better latency than any other method, especially with their latest generation system that has a max sample rate of ~400 kHz.
09-10-2012 06:14 PM
Would you mind sharing your Serial Software? This would save me time if you wouldn't mind.
09-10-2012 06:16 PM
If you would post your main software that would be super....
01-02-2013 03:23 AM
Hi friends,
I tested the communication loop from laytop => usb/rs232 convertor => rs232 connector to LK-GD500. It seems to be not successfully connected because i can't send the comment from LabVIEW and hence the setting not change accordingly! Could someone help to share some useful comments in the test? I will appreciate if you can provide any suggestions. Thanks.
01-02-2013 04:45 PM
Can you please post your LabVIEW code or a screenshot of it? Are you getting any errors? If so, can you post their code and description?
