Keyboard shortcut for probe
Is there a keyboard shortcut for switching to the probe tool? I would like to map the shortcut to a button on my mouse so that I do not have to go through the tools menu to select the probe tool.
Is there a pre-existing shortcut, and if not, can I add one?
Labview 2015 x64 and x32
(6,458 Views)
You can add your own combination in Tools->Options->Menu Shortcuts
uday
(6,448 Views)
Not too helpful, that menu region is just for the menus on the top (file, save, run), but does not have buttons for the tools.
(6,435 Views)
(6,434 Views)
Can you explain which tool exactly pointing to?
Edit: If you meant Tool selection-> You can make Automatic tool selection and use http://www.ni.com/getting-started/labview-basics/tools
uday
(6,427 Views)
Is "right click wire -> Probe" too much for you to do for your probes?
Do you use probes so much that you need a better way to do them with just one click?
(6,423 Views)
Thanks for the quick reply. I am aware of the proble watch window, but I would like to use the place probe tool itself. Automatic tool selection does not switch to tool when I mouse over a wire when the program is not running. I will probably use the probe watch windows hotkey as well.
(6,420 Views)
