10-05-2016 09:32 AM
Is there a keyboard shortcut for switching to the probe tool? I would like to map the shortcut to a button on my mouse so that I do not have to go through the tools menu to select the probe tool.
Is there a pre-existing shortcut, and if not, can I add one?
Labview 2015 x64 and x32
10-05-2016 09:45 AM
10-05-2016 10:41 AM
Not too helpful, that menu region is just for the menus on the top (file, save, run), but does not have buttons for the tools.
10-05-2016 10:41 AM
10-05-2016 11:05 AM - edited 10-05-2016 11:09 AM
Can you explain which tool exactly pointing to?
-What i thought is to open Probe Watch Window(I set as Ctrl+\ )
Edit: If you meant Tool selection-> You can make Automatic tool selection and use http://www.ni.com/getting-started/labview-basics/tools
10-05-2016 11:10 AM
Is "right click wire -> Probe" too much for you to do for your probes?
Do you use probes so much that you need a better way to do them with just one click?
10-05-2016 11:14 AM
Thanks for the quick reply. I am aware of the proble watch window, but I would like to use the place probe tool itself. Automatic tool selection does not switch to tool when I mouse over a wire when the program is not running. I will probably use the probe watch windows hotkey as well.
