KeyFocus Change Event
I wanted to trap changes in key focus, but there's no built-in event for it.  I couldn't find anything online that someone had already built, so I invented my own.  It's a bit messy under the hood, but fairly clean at the top level.
Message 1 of 9
(1,735 Views)
My Christmas wishlist:
Labview 2016
aputman
LabVIEW 2017
LabVIEW Programming
Message 2 of 9
(1,731 Views)
Nothing happened for me when I clicked either the Boolean button or the Stop button (the latter I understand ...).
I understand the logic of putting the code in a library (an .lvlib file).  But what is the reason/are the advantages of using a .llb to further "bundle" these routines?  [I partly answered my own question by using LabVIEW Help, including the Saving VIs section, but I'm still a bit unsure I completely "get it" ...]
Message 3 of 9
(1,711 Views)
Clicking on the Boolean doesn't give it  key focus.
I use .llbs as a convenient way to package a set of related VIs.
Message 4 of 9
(1,662 Views)
Here's an improved version.
Message 5 of 9
(1,653 Views)
I guess you all kudoed this (mine) idea?
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 6 of 9
(1,652 Views)
Wow, a 5-year-old, 130 (now 131) Kudo'ed Idea still hanging in there.  Go, GerdW!
Message 7 of 9
(1,634 Views)
On that old post, someone wanted the event data to include info about which control previously had focus.
This raises the question: The 'previous control' on the current VI, or the 'previous control' on any VI?
The first would be fairly easy to add.  The second, I haven't figured out a way to do that.
Message 8 of 9
(1,617 Views)
After many machinations, I came up with a version that works with multiple simultaneous VIs and also with multi-pane VIs.
Message 9 of 9
(1,589 Views)
