06-11-2019 02:49 PM
I'm using ethernet for connection, and I put in the address that showed on the 6221 as it turned on. Is there a way I should modify the software to accommodate for ethernet instead of GPIB?
06-11-2019 02:55 PM - edited 06-11-2019 02:59 PM
Oh, for the ethernet address you need to use a port.
What do you write as the VISA address ?
(some Keithley 6221 firmware do not work with ethernet. Do you have the C04 fw ?)
For the visa address you need TCPIP::" ip address" ::SOCKET or is it ::INSTR ?
Do you see the device in MAX ?
Anyway, depending on the firmware, it may not work. You may wish to contact Keithley (I did, but not get any answer so switch to GPIB).
More details are here : https://forum.tek.com/viewtopic.php?t=33800
I found this problem in 2012 !
06-11-2019 03:11 PM
I'm just putting down the ethernet ip address for the visa address. It's something like 192.168.etc. I was able to find it and successfully validate the address in MAX.
I did try both ways of rewriting the ip address, but I didn't have much luck. I think at this point I'll try to switch to a GPIB cable instead.
Thanks for you help. Hopefully switching to GPIB will get me past this.
