10-13-2011 12:50 PM
Hi All,
I'm trying to control a Keithley 2635a source meter using labview but my source meter outputs an error every time I try to run the VI "error 5038: SMUA index exceeds maximum reading"
I've looked at one other post on this topic but I can't figure out why I keep getting this error.
I've attached my VI's to this post.
Thanks for your help.
10-13-2011 04:14 PM
I fixed the problem.
I wasn't setting the number of measurements to be taken by the buffer. I needed to use a Keithley sub VI called configure measure so that the measure sub VI would know how many
measurements to take.
If anyone has a similar problem using the buffer on a Keithley 2600 series SMU then reply to this post and I'll see if I can help you out.
Thanks again.
01-23-2013 07:28 PM
I have the same problem from Keithley 2635A.
Would you post your file for my reference ?
thank you very much.
