Keithley 2450 sweep_current limit while maintaining voltage increase
I'm using Keithley 2450 sourcemeter for IV sweeping
I'm trying to source voltage sweep with current compliance; however, the voltage does not increase after the current limit point.
I'm using example of keithley 2450 read_single and I included <For loops> for sweeping voltage.
Same issues happen with the example keithley 2450 sweep and aquire.
I attached a picture explaining my situation
Can someone help me?
Thanks in advance.
(1,423 Views)
Hi Richard,
What does the device manual say about this behaviour?
Does it describe a way to create your measurement with limited current while increasing voltage?
In case of "Yes!": which commands to you need to send to the device?
After all the device is controlled via SCPI commands: you can always create your own VI to send commands and receive the measurement data, as SCPI simply means "Use VISA fro device communication"…
(1,330 Views)
This is really a Keithley forum question about how SMUs work.  They have a few modes you can use when you hit a source limit.  You will want to read the manual (p 6-91) for the :SOURce:SWEep:VOLTage:X <failAbort> feature.  In almost all cases the default is to disable the output on compliance limit and stop the sweep.  You can however change that behaviour to continue the sweep and hold V/I at the compliance limit using the SCPI command previously mentioned.
Hope that helps,
Craig
(1,310 Views)
