05-05-2020 07:36 AM - edited 05-05-2020 08:36 AM
i want to measure a resistor with a 2450 SMU by Keithley. With the systemswitch 3706A and the matrixcard 3732 i want to change between some measuring points. This means i want to close some Channels, measure the resistor and finally open the channel to change the measuring points.
The drivers are implemented at LabVIEW and they work. For example, I initialize the SMU 2450, then I want to close a channel an start the measure. It doesn't work.
Measuring the resistor only with the 2450 is fine and works. Closing and Opening a Channel only with 3732 is even no problem.
But when they work together it doesn't work 😞
How can I give a command from the 2450 to the 3706A to close the channel or to open a channel?
Can someone answer my Question?
05-05-2020 07:57 AM - edited 05-05-2020 07:58 AM
Hallo Jenni,
wie du vielleicht bemerkt hast, ist dies ein englischsprachiges Forum - und du solltest deine Fragen auf Englisch schreiben. Oder du postest im deutschsprachigen www.labviewforum.de !
Does the manuals of both devices describe how (and if) they can communicate over this "TSP-Link"? (It seems this is a question you should post in a Keithley forum and not in a LabVIEW forum…)
Why do you want to have a communication between both devices, when you can control both from your computer running your LabVIEW program?
