Keithley 236 and GPIB
I used a Ke236 source meter with GPIB control and Labview 5.1.1 on W98. My program performed sweep for source and measurement at each step.
The program have worked perfectly for seven years. Now I change to WXP and L8.6 and experience the following problem: after approximately 500 steps (it takes 1.5 hour) the program hangs.
Does anyone can help me?
Thanks in advance.
(2,675 Views)
Post your code.  We can't help if we can't see what you are doing.  It sounds like you are chewing up memory or hard drive space.
- tbob
Inventor of the WORM Global
(2,652 Views)
