Keisight 34972 Relay Control execute time very long with LabVIEW in Teststand
i use 34972 digital multi meter as relay switch, when I run the VI to control the relay to open or close, it take very long time at first run this VI in teststand every execution. I do not know why, is there anyone could give me some suggestion, thank you very much in advance.
(2,578 Views)
Posting the code you use would help solve the mystery.
(2,542 Views)
Hi cstorey thanks for reply. I ues 34972 relay, and the control command as: ":route:close@xxx" at the beginning, i will open VISA, think may be the time long here. but i do not know how to optimize, unfortunately, i could not attached any thing on this page, regards vikke
(2,511 Views)
Accepted by vikkenie
You should initialize a VISA session only once, then open/close the relay probably in a loop, then close VISA session when program termnates.  What will really slow you down is opening a VISA session (possibly resetting the instrument and querrying the instrument ID)  then closing the relay all inside a loop.  I'd guess that might take 2-5s, whereas just closing the relay should take 60ms.
Opening, reseting, ID querry should be done just once before the real measurement starts.  Using a state machine design pattern, this would be done in the INIT state.  Then in your code where things are time sensitive you send just the one command to OPEN/CLOSE the relay.
Craig
(2,498 Views)
 You are right.
(2,486 Views)
Hi Craig did you tried 34972/34970 Open VISA time, how long it take?
(2,446 Views)
Sorry, I don't have one for testing at the moment.
(2,425 Views)
