Keeping Units in a Histogram
Hello All!
I am trying to use the General Histogram.vi (Functions/Mathematics/Probability & Statistics/General Histogram.vi), and my 1-D Array input has a unit of time (us or ns).  When I connect the output of the array (output of a "for loop", double precision), I must remove the units via the "unit" (Functions/Numeric/Conversion/Convert Unit) tool, which I have used to remove the units....
Is there any way that I can keep the units while using the General Histogram.vi ?
Thanks!
Bryan
(3,178 Views)
Hi Bryan,
What do you mean when you say your array has a unit of time?
Could you send me a screen shot of your code so I can better understand your situation?
Rachel D.
(3,157 Views)
I think the only way is to turn off the units (using Convert Units) before you use the General Histogram and the turn them on again at the output.
Ian
Aray with units
(3,148 Views)
Here is an example of how I am using the general histogram.vi  .... I cannot show my actual code, as it is non-published research as of right now, but this shows my problem.
(3,140 Views)
I'll also attach the VI I made for that picture... Thank you!
(3,138 Views)
