07-07-2015 05:05 AM
I am currently trying to connect a Thermotek t255p chiller to a labview programme via RS232 port, so as to monitor the temperature of it remotely. I am just trying to set up the initial communication first and I am having difficulties.
I have set up the basic VISA read and write VI to have it communicating with the chiller, I have tried sending in *IDN? commands as well as the commands detailed in the manual for the device. But everytime, I reccieve the same response: "#i2be"
I have no idea what this response means, but I cannot get anything else out from it.. Can anyone help please?
Many thanks,
Callum
Solved! Go to Solution.
07-07-2015 05:24 AM
07-07-2015 05:36 AM
Apologies, I have now attached the manual. The commands are on page 28.
I have tried using a 'Serial port terminal' by coad.net which communicates with the terminal, it also returns #i2be. I have tried using several EOL sequences
07-07-2015 05:46 AM
07-07-2015 06:11 AM
Following the manual its says to input a Serial Watchdog command to start the connection, so using the manual's command list I have entered in as it says: 2E 55 3833 0D. But got this same response out, I tried several other commands in an attempt to get something from it (hence trying out *IDN?).
Do I need to input the commands as Hex? According to the manual only printable ASCII characters are allowed in the protocol.
07-07-2015 06:20 AM
