Your tunnel is set to Use Default if Unwired. Check to see what happens to the count in the default case, and make sure it's wired through without incrementing for all other cases.
You need to pass the count through all of the cases. If you don't wire a value to the output tunnel, it is set to output the default (0) and your count was just reset. If you are using LabVIEW 8.6 or newer, you can right-click on the output tunnel and select Linked Input Tunnel->Create &Wire Unwired Cases and it will be automatically done for you.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
