08-10-2017 11:47 AM
Hi guys I have keysight 2902A source/measure unit. I am trying to measure voltage on battery. I look for information how to measure voltage on the battery by using labview. I . coluldn't measure the voltage There is another programs but I want to measure voltage on the batrey by using labview.. is tehre anyone to help me about this topic. Thanks. Have a good day.
08-10-2017 01:19 PM
This is my labview block diagram
08-10-2017 02:30 PM
Hi we3,
maybe you should use the output of that read "multiple points" function?
It should give you some values…
Why do people hesitate to use the AutoCleanup tool before uploading images of block code? (Just a rhetorical question…)
08-10-2017 02:58 PM
I used read "multiple points" function.. still, ıcan not take tru value of battery. output is always about zero.
08-10-2017 03:05 PM
08-10-2017 05:46 PM - edited 08-10-2017 05:48 PM
I found how to measure voltage and current. but I have another problem :). now, I am using channel 1. I will measure currents and voltages on mosfet by using channel.2 how can they work as a synchronised. for example: I will measrue voltage and current from channel 1 and next channel 2 will measure current and voltage. Time delay must be very small for true measurement
08-11-2017 12:59 AM - edited 08-11-2017 01:00 AM
Hi we3,
All you need to know will be found in the manual of your DAQ device.
Did you read it?
Start with reading the specs of your K2902, then read the programming manual to learn about the possible options/commands…
08-11-2017 08:11 AM
Hi we3 !
Any update with your measure of voltage and current ? Did you found the manual of your DAQ device or the specs of K2902.
Have a great day.
09-29-2017 06:18 AM
ı found example about how to measure the current and votlage from exapmle in the driver.. I measure current and voltage at the same time. but ı have also another problem. ı need to use both of the channel. to measure current and voltage. how can ı use two channel at the sime time.
have a good day.
