to point out the obvious, you could have the user select a file int he
directory, then strip the path...
not beuatiful, but functional
torleiv
Ozan ONER wrote:
> Robert Luftensteiner wrote in message
> news:385794e8$0$20680@SSP1NO17.highway.telekom.at...
> > Ozan ONER schrieb in im Newsbeitrag:
> > <3857671f@newsgroups.ni.com>...
> > > hi, how can i select a directory using "file dialog" function in
> > "windowsNT"
> > > environment ?
> > > non of the options allows to select a directory, just open it.
> > > the file dialog for w98 has a button to select the directory ,"select
> > > current directory ".
> > > but for windowsNT, it doesn't exist
> > > thanx.
> > > ozan...
> ps : please look at attach.
> > Hi!
> > If you only want to select a directory
> > don't use Open/Create/Replace File.vi .
> > Try the "File Dialog" Advanced File Function.
> > (select mode = 3)
> hi robert,
> as i sad earlier, i am trying to select a directory using "File Dialog" in
> advanced functions in the winNT.
> and the select mode ==3;
> i am not using a function related to file opening or stg else.
> therefore, i am asking again, how can i select a directory? i think, it is
> impossible 🙂
> i dont want to write a new file dialog function for winNT to select a
> directory.
> the problem is related with winNT, i think.
> thanx.
> ozan...
