06-14-2016 12:19 AM
I was able to get readings from my joystick earlier today but all of a sudden it has stopped working. There is nothing wrong with the joystick (tested it from the control panel).
When I query the joystick and create an indicator, I see that there are two 'joysticks' on my computer. It looks like labview is recognizing the 'other' joystick, which isn't actually a joystick. Is there a way to specify which joystick I want to use (Logitech Attack 3)?
Attached is a screenshot of my interface.
Thanks!
06-14-2016 12:22 AM - edited 06-14-2016 12:23 AM
Fix:
On the initialize joystick block, create a constant for the device index specifiying which 'joystick' you want to use.
