I want to open a subvi´s front panel several times with each one operating independently. The subvi has a ring with several variables to choose to show in a graphic. The subvi is called from a button on the Main Front Panel. It is possible to, for instance, open the subvi and set it to show a temperature graphic and click again on the button to call another instance of the same subvi and select pressure for the graphic, keeping both new windows side by side? Will I still be able to access the Main Front Panel?
