Issue with Reconnecting Modbus TCP without Stopping the While Loop
Hello everyone,
I am working on a project where I need to implement logic to reconnect to a Modbus TCP connection if it is interrupted for any reason. The goal is to rebuild the connection using a refresh button without stopping the While loop.
I have tried to achieve this by using a shift register and  a Case structure (as shown in the attached image), but it seems like the communication is not working as expected.
Has anyone encountered a similar issue or have any suggestions on how to properly implement this logic in LabVIEW? Any ideas or insights would be greatly appreciated.
Thank you in advance!
(461 Views)
I never used that MODBUS library, but certainly there is a vi to close and cleanup the connection.
Close and then re-open. You should also close after the loop.
Paolo
(458 Views)
try making an "non initialized" shift register and wire that case structure to the iteration from the while loop, the case will run either when i=0 or when the button REset is pressed.
I'm not sure if you keep opening MODBUS several times without properly closing it may cause other errors.
(429 Views)
