Am currently checking on a device which has been communicated through hsdio spi, powered through power supply and the device was responding nicely 2 days back but now there is an issue where the data is all absolutely not correct and the device needs to be power on and off every time a new test sequence is to be run.
And, Is there any method of resetting the device through HSDIO signal by utilizing the GPIO pins in the device?!
If reset can be made on the memory pointer, where in and how should I do it?!
Am not able to debug this issue can anyone solve this issue. Please, in time bound situation!!
