Issue installing NI-VISA on an offline computer
I already have LabVIEW 2018 SP1 installed, and I also have NI MAX installed and I need NI-VISA to be installed. However, when I try to run the installer for NI-VISA, I get the error code exazb9.
The error code has a page on ni.com about using Batch Installer Builder to resolve this issue, but I am not sure if that is the correct approach or what output directory I should choose in that case.
I am also wondering if NI Package Manager would be useful in this case?
(1,110 Views)
Accepted by topic author kls20
Did you download the offline installer or the standard installer?  At the download page there is a link below the "Download" button that you need to use to get the offline installers.
GCentral
(1,073 Views)
I tried installing the offline version from the webpage for NI-VISA, this is the link https://www.ni.com/en-us/support/downloads/drivers/download.ni-visa.html#329456.
I think NI Package Manager was able to install it.
I am a little bit confused, however, because I can search my computer for NI MAX and I am able to find it and open it as an app, but I cannot find NI VISA in the same way and I am only able to locate a folder in documents with the same name that appears to contain help files.
Is it possible that I have downloaded and installed the wrong version?
(1,051 Views)
Never mind, I found it by including the dash. so NI-VISA worked.
(1,032 Views)
