Is trigger hold off supported by NI USB 5133?
I am trying to acquire the data and I need trigger hold off to stop the trigger for some time, but I am not getting the option in NI Scope and I don't know if Trigger Hold off is supported for NI USB 5133 device. Please help me in this regard.
(3,101 Views)
Wire session to property node>>triggering>>trigger holdoff.
(3,099 Views)
When I am connecting the wires and everything it gives error like this. I am attaching the vi also so that you can look at it.
(3,087 Views)
my external trigger is of 1.3 millisecond and after first positive edge I want to hold off for 1.4 millisecond so that I can stop the next positve edge. Is there any other solution I can use it hold off the signal. I want to get one postive edge and then leave one and then get another one.
(3,086 Views)
USB 5133 does not support the feature of Trigger Hold OFF
AB
Kudos are Accepted
(3,069 Views)
So now how I can achieve this trigger holdoff in labview. Any software method?
(3,065 Views)
Can I develop a hold off time signal and then give it to this trigger?
(3,049 Views)
