Is this snippet going to subtract the initial value from all subsequent values?
I need to save the value of an input from the first time a sub-vi is called, and subtract that value from all subsequent input values. It's a "baseline" of sorts. Will this snippet do this?
Message 1 of 10
(3,701 Views)
no, use FGV
Message 2 of 10
(3,666 Views)
Accepted by topic author jfalesi
Hi jfalesi,
When you are uncertain about the behaviour of a VI you should create a small "testbench" for that subVI…
Something like this:
There's a "First Call?" function and you can use it whenever you want to do something at the first call of a VI!
Message 3 of 10
(3,661 Views)
Almost. Show enable terminal and use a "first call?" node on that terminal. See attached VI and test VI.
Certified LabVIEW Architect
Message 4 of 10
(3,655 Views)
throls, you've written "2012", but VIs in LV 2018.
bthw, GerdW's variant better imho, because no need extra terminals.
Message 5 of 10
(3,648 Views)
Hi Artem,
But I need one more LabVIEW primitive, so I see an advantage for the Enable terminal of the feedback node!
(I hope the compiler will create the same code for both variations…)
Message 6 of 10
(3,643 Views)
Thanks. Corrected. Lol, I resaved it in 2018 to relink to the renamed file for 2012. Exchanging coffee for tea was maybe not such a good idea.
Any flavor of the solution will do.
Message 7 of 10
(3,638 Views)
Why would using "first call" have different behavior than wiring the desired value to the "initializer" terminal and setting it to "Initialize on first call"?
Message 8 of 10
(3,607 Views)
Using "Initialize on first call" will still feed each iteration's value into the feedback node. Using the Enable input and setting the value only on the first call will keep the initial value for every iteration.
Message 9 of 10
(3,585 Views)
Yes, each iteration's value will be sent back into the feedback node, but iterations don't alter the value. So once it's initialized, the initialized value should be fed back into the feedback node every time the VI is called. I would use a shift register, but this VI is executed only once per call so I don't need a while loop.
Message 10 of 10
(3,555 Views)
