Is there any way to specify the default version of LabVIEW?
I have a sinking feeling that the answer to this question is "no."  With more than one version installed, is there any way to set the default LabVIEW version for opening a VI? I have both 7.1 and 8 installed, and usually only use 8 to open an example or look at something posted here.  When I do that, it resets all the OS hooks so that the default action for opening a VI is to open it in version 8.  I've even gone so far as to create actions to open files in 7.1 and 8, but it always resets my default action.
I found this KB article for when version 7 came out, but it's suggestions don't seem to work with 7 and 8.
Ugh. I hate it when software thinks it knows what I want better than I do.
(3,881 Views)
You could try Dataact's version chooser. I haven't tried it myself, so I can't comment on how convenient it is.
___________________
Try to take over the world!
(3,873 Views)
Another option is JPD's trick here.
___________________
(3,864 Views)
Add in the LabVIEW.ini file of those versions you do not want to rewrite the registry on startup to point to themselves for VI files, the following:
RegisterExtensions=False
Of course the VersionChooser utility mentioned earlier is even more convinient.
Rolf Kalbermatter
Message Edited by rolfk on 06-28-2006 08:21 AM
Rolf Kalbermatter  My Blog
(3,846 Views)
Exactly what I was looking for! I knew it had to be there somewhere. I don't suppose these useful little undocumented tweaks are documented anywhere?
(3,824 Views)
The most comprehensive list is in Brian Renken's site.
___________________
(3,816 Views)
