Is there any way to put a picture in a Dialog Box with a caption and two buttons?
I would like to have a pop up dialog box that would show a picture with a caption and allow an operator to click 'OK' or 'Cancel'.
Has this been done before or is there any alternatives? I have thought about having two seperate pop ups but this wouldn't be as neat for a final solution.
Thanks.
Windows 7. LabVIEW 2011.
(4,085 Views)
Accepted by topic author 19jmc
Hi jmc,
             See the links below.This will be helpful to you.
             http://forums.ni.com/t5/LabVIEW/A-picture-as-a-dialog-box/td-p/236851
             http://forums.ni.com/t5/LabVIEW/Dialogbox-with-user-input-and-image/td-p/1601214
Thanks as kudos only:)
(4,074 Views)
If this is a static picture on the front panel then you can just paste a picture right on the front panel.
As for the caption, just use static text. Or does this caption need to change? If so, you will obviously need a string control as an input. You should disable the string control so that a user can't change the text.
(4,066 Views)
Thanks for your replies smercurio_fc and danil33!
The second link from danil33 was extremely similar to what I was after...the joy of using the forum!
Much appreciated.
(4,059 Views)
