Is there any way to not use coersion dot here ? & is it fine to use it
Iam preparing for my CLD certification, saw this code under the solution of the ATM application. Want to know whether it is fine to allow these coersion dots and also is there any way to avoid these.
Any other tips and examples for CLD certification will be appreciated.
Thank you
Message 1 of 9
(2,544 Views)
Accepted by topic author Ramprakash0111
These are references of different control types (Boolean, String, Cluster). Elements in an array have the same type, so input references must be  converted to a type common to all (probably a generic Control).
So: no, you can't avoid it.
Paolo
Message 2 of 9
(2,537 Views)
You can technically avoid them by using To More Generic Class, but it is not worth it.  It may cost you 1/2 a point by the automatic standards, but a good reviewer will reverse that in this instance.
Message 3 of 9
(2,526 Views)
Thank you for your reply. I understand that but still i don't want to give any chance.
Message 4 of 9
(2,519 Views)
@Ramprakash0111 wrote:
I am preparing for my CLD certification, saw this code under the solution of the ATM application.
Well, it would help to include a link to that "solution". Does it have comments? Is it considered a good solution or just some random solution?
Message 5 of 9
(2,472 Views)
The CLD example solutions are "passing" solutions.  We are not given any idea of how close the solution was to failing.
Message 6 of 9
(2,464 Views)
It wasn't entirely clear to me if that "solution" came with some official prep guide or was picked up e.g. somewhere here, for example. 😄
Message 7 of 9
(2,450 Views)
This part of code was present under Solutions in the sample exams for CLD given by NI.
Message 8 of 9
(2,393 Views)
You can find the cld sample exams file here . The page link is here .
Message 9 of 9
(2,389 Views)
